11 years agomy ep3s200f1152 has been damaged?
Hi,on my subboard there is a fpga(ep3s200f1152),now i cannot access jtag chain,as download is also not work,yesterday i had used it and it can work .My subboard is connected to bottom board which pro...
11 years ago170 ohms to GND from the TCK is far too low. So, I suspect you have damage to the FPGA.
50mA doesn't necessarily sound that bad but if it's much more than a known good unit, it doesn't look good for your 'wrong' FPGA. Yes - you can hot-plug suitable JTAG cables. That won't cause a problem. Regards, Alex
