AShar42
7 years agoMy code is making a random LED generator using LSFR. But, I want to turn on only one LED at a time, but my program is randomly generating 1-3 LED at a time.
module Memorygame
#(parameter BITS = 5)
(clk, rst_n, out);
input clk;
input rst_n;
output reg [3:0] out;
reg [3:0] out_next;
integer count=0;
reg clk_1hz;
always @ (posedge clk) begin // slows our clock from 50mhz to 1hz
if (count<25000000)
count = count +1;
else begin
clk_1hz = ~clk_1hz;
count = 0;
end
end
always @* begin // responsible for determing the blinking of the leds
out_next = out;
repeat(BITS) begin
out_next = {out_next[2:0],(out_next[3]^out_next[0])};
end
end
always @(posedge clk_1hz or negedge rst_n) begin
if(!rst_n)
out <= 4'h1f;
else
out <= out_next;
end
endmodule
1 Reply
- Abe
There are a couple of issues.. check out this code and try if it works.. this is the correct way to implement a LFSR.
`timescale 1ns/1ns module Memorygame ( input wire clk, input wire rst_n, output reg [3:0] out ); integer count; reg clk_1hz; wire lf; // linear feedback of XORed bits. always @ (posedge clk or negedge rst_n) begin // slows our clock from 50mhz to 1hz if(!rst_n) begin count = 0; clk_1hz <= 1'b0; end else begin if (count<250000) count <= count + 1; else begin clk_1hz <= ~clk_1hz; count <= 0; end end end //always assign lf = !(out[3] ^ out[0]); always @(posedge clk_1hz or negedge rst_n) begin if(!rst_n) out <= 4'b0000; else begin out <= {out[2],out[1], out[0], lf}; end end //always
