AShar42
7 years agoMy code is making a random LED generator using LSFR. But, I want to turn on only one LED at a time, but my program is randomly generating 1-3 LED at a time.
module Memorygame #(parameter BITS = 5) (clk, rst_n, out); input clk; input rst_n; output reg [3:0] out; reg [3:0] out_next; integer count=0; reg clk_1hz; always @ (posedge clk) begin // sl...
Abe
7 years agoThere are a couple of issues.. check out this code and try if it works.. this is the correct way to implement a LFSR.
`timescale 1ns/1ns
module Memorygame
input wire clk,
input wire rst_n,
integer count;
reg clk_1hz;
wire lf; // linear feedback of XORed bits.
always @ (posedge clk or negedge rst_n) begin // slows our clock from 50mhz to 1hz
if(!rst_n) begin
count = 0;
clk_1hz <= 1'b0;
end
else begin
if (count<250000)
count <= count + 1;
else begin
clk_1hz <= ~clk_1hz;
count <= 0;
end
end
end //always
assign lf = !(out[3] ^ out[0]);
always @(posedge clk_1hz or negedge rst_n) begin
if(!rst_n)
out <= 4'b0000;
else begin
out <= {out[2],out[1],
out[0], lf};
end
end //always
