you need create an interface to the megafunction, but the megafunction itself already exists in the altera libraries.
Sorry to ask this, how to create an interface to the megafunction? I never use this function.
for example this is my previous codes: library ieee; use ieee.std_logic_1164.all; library floatfixlib; use floatfixlib.fixed_pkg.all; entity my_mult is port ( clk : in std_logic; a,b : in sfixed(3 downto -4); c : out sfixed(7 downto -8) ); end entity my_mult; architecture rtl of my_mult is begin mult_proc : process(clk) begin if rising_edge(clk) then c <= a * b; end if; end process; - Altera_Forum
you are using fixed point, not floating. There is no need to instantiate floating point megafunctions.
But the megawizard creates the files and component declarations you need. You just connect it up with a port map ie.my_inst : some_entity port map ( clk => clk, input1 => signal1, input2 => signal2 ....etc ); - Altera_Forum
Yes the code above is doing fixed point. i also doing for floating point.
how are you doing floating point? the floatfixpkg.float_pkg.all will not produce very good hardware results.
Yeah... i plan to do new program for floating point application. But the problem is i still don't know how to start the programming. i still figure it out. Do you have any sample coding for others application like addition or subtraction? what library to include and the method of writing the code?
What files should added while create a new project wizard?
You need to create VHD files from the mega wizard. You should also get a .cmp file, that contains the component declaration. Copy and paste this into your design file, and conecct up the ports something like this:
Then include your source file and the megawizard generated .vhd file in your project.library ieee; use ieee.std_logic_1164.all; use ieee.numeric_std.all; entity fpadder is port ( ------------------------------------------------------------ --Clock and reset ------------------------------------------------------------ clk : in std_logic; a,b : in std_logic_vector(31 downto 0); c : out std_logic_vector(31 downto 0); ); end entity; architecture rtl of fpadder is component my_fpadder PORT ( clock : IN STD_LOGIC ; dataa : IN STD_LOGIC_VECTOR (31 DOWNTO 0); datab : IN STD_LOGIC_VECTOR (31 DOWNTO 0); result : OUT STD_LOGIC_VECTOR (31 DOWNTO 0) ); end component; begin inst1 : my_fpadder port map ( clock => clk, dataa => a, datab => b, result => c ); end rtl; - Altera_Forum
Thanks Tricky. I'll figure it out. Thanks for your help.
