15 years agoMultiplication on floating point format
question: in order to use the quartus ii to do the calculation (multiplication) of floating point, may i know what is the format type used in quartus ii to convert the floating point value to bina...
15 years agoyou are using fixed point, not floating. There is no need to instantiate floating point megafunctions.
But the megawizard creates the files and component declarations you need. You just connect it up with a port map ie.
my_inst : some_entity
port map (
clk => clk,
input1 => signal1,
input2 => signal2
....etc
