15 years agoMultiplication on floating point format
question: in order to use the quartus ii to do the calculation (multiplication) of floating point, may i know what is the format type used in quartus ii to convert the floating point value to bina...
15 years agoYou need to create VHD files from the mega wizard. You should also get a .cmp file, that contains the component declaration. Copy and paste this into your design file, and conecct up the ports something like this:
library ieee;
use ieee.std_logic_1164.all;
use ieee.numeric_std.all;
entity fpadder is
port (
--Clock and reset
clk : in std_logic;
a,b : in std_logic_vector(31 downto 0);
c : out std_logic_vector(31 downto 0);
end entity;
architecture rtl of fpadder is
component my_fpadder
PORT
clock : IN STD_LOGIC ;
dataa : IN STD_LOGIC_VECTOR (31 DOWNTO 0);
datab : IN STD_LOGIC_VECTOR (31 DOWNTO 0);
result : OUT STD_LOGIC_VECTOR (31 DOWNTO 0)
end component;
begin
inst1 : my_fpadder
port map (
clock => clk,
dataa => a,
datab => b,
result => c
end rtl;
Then include your source file and the megawizard generated .vhd file in your project.
