12 years agoMultiple High Speed ADCs via serial LVDS
Hi everybody, for a new system there is the need to digitize data with 12 Bit/80Msps from up to 20 channels. To date the idea would be using multiple Quad ADCs with serial LVDS links source ...
12 years ago --- Quote Start --- The ADC can output the data over 2 lanes, halving the speed requirements to only 480 MBit/s which can be handled, hands down, by a simple deserialiser, using the DCO as the main clock. In a project, a couple of years back now, I deserialised 4 octal ADCs running 50 MHz or 600 MBit/s on an EP2C8F256-C6N. No need for calibration. --- Quote End --- Hi josyb, Thanks for you informations. In some 8-channel ADCs, there are two DCO, which means each DCO in charge 4-channel. Same as FCO. So in some cases one fpga maybe want to connect multi-ADC chips, the channels are too much and there are not enough didcated serdes inside FPGA. We need to use DDIO + Shift-Register to receive the ADC data, as attached image shows. It seems we don't need to use the DCO.
