17 years ago
Multiple drivers due to always enable I/O buffer
Error information: the NODE xxxx has multiple drivers due to always enabled I/O buffer.
Is there any expert to explain how this kind of error happens? and how to fix it?
Thanks and best regards
Calvin
    Sorry, I don't clearly understand the structure of the said node, where you connected tri-state drivers and what are the involved module port types (in, out, inout?)
    Hi FvM,Thanks for your reply! the error information is as the following:
    Error: The node "upinter:x4|reg522:x5|x322:g116|vflg" has multiple drivers due to the always-enabled I/O buffer "upinter:x4|reg_datar_16"
    when I do synthesising for the individual 'module upinter', there is no such error showing.
    when I do synthesising for the top 'module adg522' individually, there is no such error showing either.
    but when I added the module upinter into the top module adg522 and then do synthesising, many this kind of errors comes out.
    the pin of 'reg_datar_16" is a input port of D in the module upinter. in the other modules, it is a tri-state output.
    You may want to clarify, which drivers for the said exist in your design. Also the error message is supplemented by additional information about involved drivers, usually.
