17 years agoMultiple drivers due to always enable I/O buffer
Error information: the NODE xxxx has multiple drivers due to always enabled I/O buffer. Is there any expert to explain how this kind of error happens? and how to fix it? Thanks and best regards ...
17 years agoHi FvM,Thanks for your reply! the error information is as the following:
Error: The node "upinter:x4|reg522:x5|x322:g116|vflg" has multiple drivers due to the always-enabled I/O buffer "upinter:x4|reg_datar_16" when I do synthesising for the individual 'module upinter', there is no such error showing. when I do synthesising for the top 'module adg522' individually, there is no such error showing either. but when I added the module upinter into the top module adg522 and then do synthesising, many this kind of errors comes out. the pin of 'reg_datar_16" is a input port of D in the module upinter. in the other modules, it is a tri-state output.
