18 years agoMultiple Distinct Clocks Error
Hello everyone,
I am trying to write some code to use the debounced keys on the Altera DE2 board. I have spent days on the same error: "Error (10820): Netlist error at lab1.vhd(49): can't infer register for CurAddr[0] because its behavior depends on the edges of multiple distinct clocks"process(clock, resetn)
variable CurAddr : std_logic_vector(3 downto 0);
variable CurData : std_logic_vector(7 downto 0);
variable output : std_logic_vector(6 downto 0);
begin
if(clock'EVENT and clock='1') then
if(key(3)'EVENT and key(3)='0') then
if(conv_integer(CurAddr) = 16) then
CurAddr := "0000";
end if;
CurAddr := CurAddr + "0001";
elsif(key(2)'EVENT and key(2)='0') then
if(conv_integer(CurAddr) = 0) then
CurAddr := "1111";
end if;
CurAddr := CurAddr - "0001";
elsif(key(1)'EVENT and key(1)='0') then
if(CurData = "11111111") then
CurData := "00000000";
end if;
CurData := CurData + 1;
elsif(key(0)'EVENT and key(0)='0') then
if(CurData = "00000000") then
CurData := "11111111";
end if;
end if;
end if;
ram_addr <= CurAddr; --STORE RAM_ADDR
data_in <= CurData; -- STORE DATA
hex6 <= led_out1; -- OUTPUT LED CODE
end process; I have tried removing the key(#)'EVENT parts. This removes the error but then the Seven Segment Display increments randomly it seems. I am using the 4 keys on the DE2 to control a RAM address and increment or decrement the value in that address. 2 keys to increment/decrement the address and 2 to control the value. I have also tried chaning the variables to signals. This didn't help either. I have also tried changing it to process(key) and removing the 'EVENT part as well as changing key(3)'EVENT to key(3)'last_value='1'. I am having no luck or intelligence. Any suggestions? Thank you. V/R, Alan
