19 years agoMultiple Distinct Clocks Error
Hello everyone, I am trying to write some code to use the debounced keys on the Altera DE2 board. I have spent days on the same error: "Error (10820): Netlist error at lab1.vhd(49): can't infe...
14 years agoI have the similar error when I try to compile a code to stretch an input pulse for some clock cycles .
The code compiles and simulates perfectly,except when I add the line "shp_out<=shaped_output"..where I tryto put the signal shaped_output into the port shp_out. It gives me an Error (10820):: can't infer register because its behavior depends on the edges of multiple distinct clocks entity integrate1 is port ( trig : out std_logic; trigger_input,clk_pulse: inout STD_LOGIC ); end integrate1; architecture arc of integrate1 is signal shaped_output: std_logic:='0'; signal tmp: std_logic_vector(10 downto 0); signal shp_out:std_logic; begin process (clk_pulse,trigger_input) begin if (rising_edge(trigger_input)) then tmp<="00000000000"; shaped_output<='1'; end if; if shaped_output='1' then if (tmp="00000000100") then tmp <= "00000000000"; shaped_output<='0'; elsif (clk_pulse'event and clk_pulse='1') then tmp <= tmp + 1; end if; end if; end process; shp_out<=shaped_output;<<<<<<<<<<----------PROBLEM end arc;
