18 years ago
Multiple Distinct Clocks Error
Hello everyone,
I am trying to write some code to use the debounced keys on the Altera DE2 board. I have spent days on the same error: "Error (10820): Netlist error at lab1.vhd(49): can't infer register for CurAddr[0] because its behavior depends on the edges of multiple distinct clocks"
process(clock, resetn)
		variable CurAddr : std_logic_vector(3 downto 0);
		variable CurData : std_logic_vector(7 downto 0);
		variable output : std_logic_vector(6 downto 0);
		begin
		if(clock'EVENT and clock='1') then
			if(key(3)'EVENT and key(3)='0') then
				if(conv_integer(CurAddr) = 16) then
					CurAddr := "0000";
				end if;
				CurAddr := CurAddr + "0001";
			elsif(key(2)'EVENT and key(2)='0') then
				if(conv_integer(CurAddr) = 0) then
					CurAddr := "1111";
				end if;
				CurAddr := CurAddr - "0001";
			elsif(key(1)'EVENT and key(1)='0') then
				if(CurData = "11111111") then
					CurData := "00000000";
				end if;
				CurData := CurData + 1;
			elsif(key(0)'EVENT and key(0)='0') then
				if(CurData = "00000000") then
					CurData := "11111111";
				end if;
			end if;
		end if;
			ram_addr <= CurAddr; --STORE RAM_ADDR
			data_in <= CurData; -- STORE DATA
			hex6 <= led_out1; -- OUTPUT LED CODE
		end process;
I have tried removing the key(#)'EVENT parts. This removes the error but then the Seven Segment Display increments randomly it seems. I am using the 4 keys on the DE2 to control a RAM address and increment or decrement the value in that address. 2 keys to increment/decrement the address and 2 to control the value. I have also tried chaning the variables to signals. This didn't help either. I have also tried changing it to process(key) and removing the 'EVENT part as well as changing key(3)'EVENT to key(3)'last_value='1'. I am having no luck or intelligence. Any suggestions?
Thank you.
V/R,
Alan
    I have the similar error when I try to compile a code to stretch an input pulse for some clock cycles .
    The code compiles and simulates perfectly,except when I add the line "shp_out<=shaped_output"..where I tryto put the signal shaped_output into the port shp_out.
    It gives me an Error (10820):: can't infer register because its behavior depends on the edges of multiple distinct clocks
    entity integrate1 is
    port (
    trig : out std_logic;
    trigger_input,clk_pulse: inout STD_LOGIC
    end integrate1;
    architecture arc of integrate1 is
    signal shaped_output: std_logic:='0';
    signal tmp: std_logic_vector(10 downto 0);
    signal shp_out:std_logic;
    begin
    process (clk_pulse,trigger_input)
    begin
    if (rising_edge(trigger_input)) then
    tmp<="00000000000";
    shaped_output<='1';
    end if;
    if shaped_output='1' then
    if (tmp="00000000100") then
    tmp <= "00000000000";
    shaped_output<='0';
    elsif (clk_pulse'event and clk_pulse='1') then
    tmp <= tmp + 1;
    end if;
    end if;
    end process;
    shp_out<=shaped_output;<<<<<<<<<<----------PROBLEM
    end arc;
    Don't use two clocks in the same process. Just read and act on the trigger input inside the "elsif (clk_pulse'event and clk_pulse='1')" part of the process.
