9 years agoMultiple Configuration File for Cyclone IV E
Hallo I am using Cyclone IV E (EP4CE22F17C6) with a slightly customized DE0-NANO board. Currently i am using the JTAG to program the FPGA and its volatile. I know that the board has an EEPROM w...
9 years agoHallo Alex
Thanks for your answer. Just to make sure i understood you clearly i need a combination of a SD card and a micro controller. I will store the FPGA images in the SD card, connect the SD card to the micro controller and connect the micro controller to the FPGA. Then using a Passive configuration i can configure the FPGA using the data from the SD card.
