14 years agomultiple chip select is not supported by cyclone iii?????
I use ddr2 HPC.
when i set "chip selects per DIMM=2" and "Total Memory chip selects=2". I get an error :Multiple chip select is not supported by cyclone iii.(quartus ii 9.0) i used quartus ii 9.1 ,there was not error.but nios ii eds 9.1 can`t work perfectly on win7.So i changed to 9.0.But this new error happened . what should i do????:confused: P.S. there was also a warning :"calibration performed on all chip selects;timing analysis only performed on first chip select.manual timing derating is required ." can i ignore it?3 Replies
Seems to be an undocumented limitation respectively a bug. Ask Altera.
Any one can help??
the ddr2 sdram is MT47H256M8.(MICRON)
Row address------------- 16K A[13:0] Bank address------------ 8 BA[2:0] Configuration------------- 16 Meg x 8 x 8 x 2 Column address---------- 1K A[9:0] Rank address-------------- 2 CS#[1:0]
