11 years agoMultifunction PCIE on Altera FPGA
Hi all, I need some infos about the possibility to have a fully multifunction in an Altera FPGA. I've searched around the web, but Ive found only paper ( Altera paper ) that talk about PCIE, b...
11 years agoHi campo8558,
Mind further elaborate on the multifunction PCIe that you are referring? Is it that you are trying to have multiple PCIe instances in the FPGA? If yes, there should not be issue doing so as long as your selected device has sufficient PCIe resources.
