12 years agoMulticycle custom instruction repeated calls, hangs, signals
I have some problems with a multicycle custom instruction. I'm using a Terasic DE1 board with Quartus II 13.01 64 bit on Ubuntu 12.04. I've started with the NIOS II system for "count_binary" example. It works, more or less. Sometimes I get errors of mismatch ID or timestamps that I must solve with deleting Run environment of, at worst, reprogramming the FPGA. (Is it normal..??) Starting from this system, I've eliminated the PIO that is used to display the counter by boards leds. Still ok. At this point I've added this custom instruction (it's only and example, I know it's stupid):
library ieee;
use ieee.std_logic_1164.all;
use ieee.numeric_std.all;
entity dci4 is
port (
CLK: in std_logic;
CLK_EN: in std_logic;
RESET: in std_logic;
START: in std_logic;
DATAA: in std_logic_vector(31 downto 0);
DATAB: in std_logic_vector(31 downto 0);
RESULT: out std_logic_vector(31 downto 0);
DONE: out std_logic
end dci4;
architecture Behavior of dci4 is
begin
process(CLK)
variable IDATAA: integer;
variable IDATAB: integer;
variable STATE: integer;
begin
if (rising_edge(CLK)) then
if (RESET = '1') then
RESULT <= (others => '0');
DONE <= '0';
IDATAA := 0;
IDATAB := 0;
STATE := 0;
elsif (CLK_EN = '1') then
case STATE is
when 0 =>
if (START = '1') then
STATE := 1;
else
STATE := 0;
end if;
when 1 =>
IDATAA := to_integer(unsigned(DATAA));
IDATAB := to_integer(unsigned(DATAB));
STATE := 2;
when 2 =>
IDATAA := IDATAA +1;
IDATAB := IDATAB -1;
if (IDATAB = 0) then
RESULT <= std_logic_vector(to_unsigned(IDATAA, RESULT'length));
DONE <= '1';
STATE := 3;
end if;
when 3 =>
DONE <= '0';
STATE := 0;
when others =>
STATE := 0;
end case;
end if;
end if;
end process;
end Behavior;
Problems starts here: the c.i. seems to hang and nothing is returned. Any suggestion is HIGHLY welcome. Are START, RESULT and DONE correctly managed? Am I doing something really stupid (consider that ModelSim simulation on the above code give correct results). Thanks
