12 years agoMulticycle custom instruction repeated calls, hangs, signals
Hello, I have some problems with a multicycle custom instruction. I'm using a Terasic DE1 board with Quartus II 13.01 64 bit on Ubuntu 12.04. I've started with the NIOS II system for "count...
12 years agoI've solved.
The problem was a timer component, in Qsys, set to 1 nanosecond resolution.... DE1 has a 50MHz clock. Changing the resolution to 20 ns makes all things work as expected. Thanks all!
