12 years agoMulticycle custom instruction repeated calls, hangs, signals
Hello, I have some problems with a multicycle custom instruction. I'm using a Terasic DE1 board with Quartus II 13.01 64 bit on Ubuntu 12.04. I've started with the NIOS II system for "count...
12 years agoFor what it's worth, after you stop using 'U' as dsl described, your custom instruction VHDL that you pasted is fine.
Whatever hang you're seeing is not caused by the VHDL you pasted, and it is something else. If you're not able to figure it out, my suggestion would be to post a .zip of a simplified project (NIOS+Onchip SRAM+your custom instruction) that others can compile and run.
