16 years agoMulticycle Constraint
I get confused by the altera article on applying multicycle exception(www.altera.com/literature/an/an481.pdf (http://www.altera.com/literature/an/an481.pdf)) especially on the hold check. It seems t...
16 years ago1) The hold check is correct and should be negative. Note that a negative hold check makes timing easier to make, as you want your data delay(minus clk skew) to be longer than the hold check. In this example, there is a phase shift on the latch clock. So when the launch clock at time 10ns sends data, the setup check is that it gets their before the latching clock at time 12ns and after time 2ns, i.e. it must be shorter than 2ns and longer than -8ns.
2) The figure above it, although the lines don't exactly match up. Note that the setup and hold checks are over time. In essence, every transfer over time is checked. That's why, if you have two unrelated clocks, the setup check might be tens of thousands of ns later in time. That's because it does thousands of checks before finding the most restrictive setup. I posted a .ppt on this forum that goes over setup and hold and multicycles: http://www.alteraforum.com/forum/showthread.php?t=1845&highlight=timing Personally, I think it's a lot easier, as it's less equations and more conceptual. Most importantly, don't bury yourself in understanding the guide. You have some circuit where you should know what the setup and hold requirements should be(if you don't know what you want, TimeQuest can't help you. TQ is not for helping you figure it out, it's for allowing you to tell the fitter and timing sign-off how the circuit works). Anyway, just make up some multicycle setup and hold values and see what analysis you get. Tweak them until it returns what you want. (Note that multicycles ONLY affect the launch and latch edge of an analysis, and nothing else...) So that's all you need to look at.
