13 years agomSGDMA stride reads/writes
Has anyone used the Stride feature (available with the extended descriptor)? I using the Qsys PCIe example design on the wiki. When I enable the extended descriptor and stride option, the data tran...
12 years agoHi BadOmen,
I have the same Problem: I need two "as wide as can be"-FiFos for some outside-of-QSYS-Logic (one to write and one to read). I also took the MM-Solution, but your way seems to be the better one. I tried to implement it somehow but without success. Can you explain it for a dummy like me, which IP I have to implement and what has to be configured? Thanks Steffen
