15 years agoMove data from NIOS to hardware and then back to NIOS
I am trying to do a little calculation in hardware but I'm stuck on how to get started. I'm a complete newbie, but after reading a lot of manuals and demos, I figured out that I could have a soft pro...
15 years agoThank you everybody for the tips but I am now more lost than before :)! OK let's start somewhere. Please correct me where I am wrong.
1) Starting with normad's PIO suggestion, I inserted three 16-bit PIO ports (2 in and 1 out) in SOPC Builder. I called them line_1_in, line_2_in and result_out respectively. Each one has a Base and End address assigned by SOPC, e.g. 0x08200000-0x0820000f for the line_1_in. Then I declared these ports in the top level .v file. as: input LINE_1_DATA; input LINE_2_DATA; output RESULT_BACK; and added these lines also to the internal modules: .in_port_to_the_line_1_in (LINE_1_DATA), .in_port_to_the_line_2_in (LINE_2_DATA), .out_port_from_the_result_back_out (RESULT_BACK), My new queries: - What clock do I assign to these PIOs? Now they are at 50 MHz like all other components. - To go back to the C-code now, how do I tell NIOSII to send data to these PIOs? I am assuming that I need to make use of pointers to read the memory address, but then I don't know how to move to the next step. I am not too sure how to get get rid of the for-loop either. Any suggestions please? volatile int * line_1_ptr = (int *) 0x08200000; // Port_in_1 address volatile int * line_2_ptr = (int *) 0x08200010;// Port_in_2 address volatile int * result_back_ptr = (int *) 0x08200020;// Port_out_result *line_1_ptr = line1; // But line1 is an array *line_2_ptr = line2; // line2 is an array store_val = * result_back_ptr; 2) How do I write a process with a clock input as suggested by nophutwern? 3) This is my first attempt at writing a verilog module. I don't even know how to compile it :), but I just wanted to know if this the type of code that will do the calculation as the data comes in : module my_sum_prod ( // Inputs clk, line_1_in, line_2_in, // Output result_out ); //Port Declarations // Inputs input clk; input [15:0] line_1_in; input [15:0] line_2_in; // Output output [15:0] result_out //Internal registers reg [15:0] original_line_1; reg [15:0] original_line_2; reg [15:0] temp_sum; reg [15:0] final_result_out; temp_sum <= 16'd0; final_result_out < 16'd0; always @(posedge clk) begin temp_sum <= original_line_1 * original_line_2; final_result_out <= final_result_out + temp_sum; end assign result_out = final_result_out ; endmodule 4) When I manage to do a proper verilog module, where and how I do call it in my main .c file such that it accepts the data from the NIOS processor through the PIOs and return a value again? Thank you again. I'm just entering this whole FPGA world and I need step-by-step help. NB: To nophutwern: I will try the FIFO as soon as I get this methodology working. It's part of my learning process.
