15 years agoMove data from NIOS to hardware and then back to NIOS
I am trying to do a little calculation in hardware but I'm stuck on how to get started. I'm a complete newbie, but after reading a lot of manuals and demos, I figured out that I could have a soft pro...
15 years agoHi vivasam,
1) for loops in verilog aren't synthesizable, they are only working in simulation. You have to write a process with a clock input. On every clock cycle it will be processed one time - so you can do the mathematical operations. Maybe you need a second process to count the cycles and abort the loop. 2) the verilog module have to be saved in the quartus-project folder or a subfolder. You can use the quartusII software to create the verilog module, and modelsim to simulate it. 3) DMA is not the right way to communicate between nios and hardware. You can use FIFOs or DUALPORT-RAMs to communicate. FIFOs are easier to use. You can implement this functions bei using the MEGAWIZARD in quartusII software, both are standard modules. When you got different clocks for your nios and the verilog-module you should use clock-crossing FIFOs. As normad said you can also use the PIO (a module for sopc-builder), but be careful with the clocking.
