8 years agoMotor on DEO Board
Can I use dc motor on DEO Board on the GPIO pins?
8 years ago --- Quote Start --- Can I use dc motor on DEO Board on the GPIO pins? --- Quote End --- Do you mean directly connect a DC motor to the FPGA pins? NO, that is almost certainly not possible, unless it is a very small low power motor. So what you will need is some type of a motor driver board; usually they have two or four reasonably high current capable MOSFET devices.
