Sijith
3 years agoModifying the PCIe DMA transfer example design for Arria 10 device.
I have a modified version of the PCIe DMA transfer example design (mentioned in the Chapter 7 of attached user manual). As a modification to the example design, I added a custom generated da...
AdzimZM_Altera
3 years agoHi Sijith,
I have sent an email to you. Please let me know in case you are not receiving it.
I am thinking that the memory address should also specified whenever you want to perform transaction into the memory.
I may suggest you to add address parameter as well.
Is there any way that you can confirm the data is successfully written into the memory?
It's will be great to have that as well.
Another thing is have you ever tested the design in simulation mode?
Adzim
