nome
3 years agoModelsim stuck in clock_div loop
Hello
I am using Arria FPGA configuration from Max II CPLD with m29ew parallel flash x8 mode I am not using PFL megacore IP.
I am using configure fpga by using config_controller.vhd from intel...
ShengN_altera
3 years agoHi Nome,
Based on the code provided, I had commented out those two modules config_state_machine and config_control_signal instantiations since not provided.
I noticed you have commented out all the RESET_n port connection and instantiated signal RESET_n to '0' with signal RESET_n : std_logic := '0'; So signal RESET_n will be always '0'. Also, signal MAX_EN is always '0' as well. That's why it will stuck in clock_div loop and keep resetting like below pic.
If instantiated signal RESET_n to '1' with signal RESET_n : std_logic := '1'; It will no more stuck in clock_div loop like below pic.
Sheng
