8 years agoModelsim fails (vlog-2726) failed to access library..!
Hello! I'm attempt to simulate my quartus Prime 17 project.. Project is simply 2 blocks for frame coding/decoding (already well simulated..) plus a Transceiver PHY block.. (no controller, I us...
8 years agothanks for tip! I found the problem, due to my wrong strategy creating new project! I make a copy of an QSYS IP, but this is not correct. All IPs must be Re-generated starting from QSYS entry! ... Now Modelsim works fine!
