Mm74hc154 Fpga
hi friends
im doing a project on MM74HC154 FPGA 4-to-16 line decoder i need some ideas and informations... waiting for your replies shimaz16 Replies
I can't see anything wrong with your code... What does the simulation output look like?
i have send my vhdl coding to ur inbox..check it tel me the wrong where i have done,and hope u vl correct me
Show us your code and we could help you
im getting a different wave form of vhdl compaire to the wave form of shematic diagram verilog program..why im nt getting the output as same when i do my vhdl programming for mm74hci54 4-16 line decoder....hope you will help me,,
regards shimaz - Altera_Forum
What output do you get now and what do you expect to get?
im trying to simulate in vhdl since 4th of july 2009..i dnt no why im nt getting the exact output as schematic simulation..im mently failed for this..
You may not find the exact code for what you are looking for, but at least you'll learn how to do it. It's not that difficult.
in this book do i get the information to do the verilog programing for MM74HC14 FPGA4-16 decoder ..im extremly sory for trubling you...hope you wont mistake me
If you are new to VHDL the best is to buy a good book. This is important as designing hardware in VHDL or Verilog is quite different than programming in C/C++ or Java.
There are many good books out there on VHDL and Verilog. If you are interested in learning VHDL, I can recommend : "the designer's guide to vhdl (http://www.ashenden.com.au/vhdl-book/dg3e.html)" from Peter Ashenden. - Altera_Forum
can you give me the exact link for the vhdl
