18 years agoMissing virtual jtag documentation
Hello, I started to use the sld_virtual_jtag Megafunction for low level debugging puposes, using Tcl interface with quartus_stp. Now I'm considering possible operation with non-Altera JTAG inte...
15 years ago --- Quote Start --- Because when I tried to get the SLD_NODE information by issuing the HUB_INFO Instruction like you have described in your earlier post --- Quote End --- I don't know if it is directly related to your problem, but things changes in this regard since we started this thread. Altera already disclosed and published the relevant information about SLD. There are even a couple of design examples provided by Altera. --- Quote Start --- So is there a way for me to check if the SLD Hub is even implemented? and if it is, is it implemented correctly? --- Quote End --- There is a debug pane at the Quartus compilation report. The pane is enabled when you use the Virtual Jtag megafunction.
