18 years agoMissing virtual jtag documentation
Hello, I started to use the sld_virtual_jtag Megafunction for low level debugging puposes, using Tcl interface with quartus_stp. Now I'm considering possible operation with non-Altera JTAG inte...
15 years ago --- Quote Start --- The problem is usually related to TCK signal quality. Some JTAG actions, e.g. configuration download are working, other actions are not working. In one case, JTAG was working well, after I put a small capacitor (22 pF) in parallel to the TCK pull-down resistor (near the FPGA). --- Quote End --- Thanks for your reply. Do you think there might be a problem with the SLD Hub? Because when I tried to get the SLD_NODE information by issuing the HUB_INFO Instruction like you have described in your earlier post, all I get returned is 0x0F. So I guess that means that no sld node is being detected somehow. So I am thinking there might be a problem with the SLD_HUB. So is there a way for me to check if the SLD Hub is even implemented? and if it is, is it implemented correctly? Thank You, Jack
