18 years agoMissing virtual jtag documentation
Hello, I started to use the sld_virtual_jtag Megafunction for low level debugging puposes, using Tcl interface with quartus_stp. Now I'm considering possible operation with non-Altera JTAG inte...
15 years ago --- Quote Start --- Did you check, if standard virtual JTAG components (e.g. Signal Tap II, Source & Probe, In-system memory content editor) are working with your board? If not correctly, you have a hardware issue with your JTAG interface. --- Quote End --- You were right! I tired using Signal Tap II and it didn't work with my board but it worked on the Altera's Development board. I guess the problem is a hardware issue with my JTAG interface but I tired using the JTAG Chain Debugger in Quartus II Programer, it was able to detect the FPGA (I'm using Stratix II EP2S15F484C5) on my board correctly. Do you have any suggestions as to how I would go about debugging this hardware issue with the JTAG interface? Much Appreciated, Jack
