MAlek2
7 years agoMIPI D-PHY transmitter on MAX 10 output buffers
Hello! I'm trying to implement MIPI D-PHY transmitter on MAX 10 Dual supply FPGA. In Application Note 754 it is written that: High-speed mode — A differential buffer is used to transmit signals. ...
SreekumarR_G_Intel
7 years agoHello ,
Actually if the differential line both the end biased with 1.2V m then the Differential voltage is Logic 0 right ? then the output of the is also logic 0.Please note buffer input impedance is high and output impedance is low.Hence even if you apply 1.2V buffer wont burnt out :)
Before answering to your question can i know are you following the AN 745 application notes ?Also are you using the SN65MVVD200A ?
Thank you,
Sree
