MAlek2
7 years agoMIPI D-PHY transmitter on MAX 10 output buffers
Hello! I'm trying to implement MIPI D-PHY transmitter on MAX 10 Dual supply FPGA. In Application Note 754 it is written that: High-speed mode — A differential buffer is used to transmit signals. ...
SreekumarR_G_Intel
7 years agoHello there ,
Thank you for the questions ,
Answer to your questions are below
1. Max 10 use the soft LVDS which wont support the bi-directional flow. you can either configure as TX or RX.To implement the bi-directional mode use the GPIO IP core with differential mode turned ON.
2. Can you please clarify about OE? output enable for transmitter you mean ? I dont know what you mean by " do we really need buffer" If you are using Bidirectional it is require to use OE.
3.For BLVDS as i mentioned you are using the GPIO IP core with differential mode.
can you find the date rate of differential IO standrad in below datasheet link
https://www.intel.com/content/dam/www/programmable/us/en/pdfs/literature/hb/max-10/m10_datasheet.pdf
thank you ,
Sree
