15 years agominimum time for IO pin to damage
hello all, there is a question about the minimum time for an IO pin of the FPGA like the cyclone EP1C6Q240.. I want to know the min. time for the pin to damage when it is exposed to a vo...
15 years agoI am using the DIODE ARRAY ESD 3.3V IC for protection and here is the datasheet of it http://www.nxp.com/documents/data_sheet/pesdxs4ud_ser.pdf
the card we design has 128 point need protection so we use 44 ICs, each one of them is used to protect 3 points Bidirectional there is no enough space for more ICs.. what should I do?? remove these ICs and put diodes or what??
