8 years agomigration from EPCQ to EPCQ-A
Hi, on a custom board we have successfully used an altera Cyclone V (5CEBA2) with an EPCQ32 (ASx4). Now we had to migrate from the EPCQ32 to the EPCQ32A. We used Quartus Prime Lite 17.1.0 a...
Irionhead
7 years agoHi everybody,
is there any new knowledge about this problem?
I testet Winbond W25Q128JVEIQ flashes and got the same problem. I soldered capacitors (10pf 0805) between the Data lines and ground, on some boards this solution work fine but not at all.
So i changed to Cypress S25FL128SAGNFI01 with this flash device all boards run without capacitors, but not stable.
Every 10 times the configuration fails.
Does anybody know a flash device with WSON-8 (8x6mm) package that runs reliable?
