8 years agomigration from EPCQ to EPCQ-A
Hi, on a custom board we have successfully used an altera Cyclone V (5CEBA2) with an EPCQ32 (ASx4). Now we had to migrate from the EPCQ32 to the EPCQ32A. We used Quartus Prime Lite 17.1.0 a...
8 years agoHi rbatfmi,
Out of 25 boards with the EPCQ32A , 4 works well (16%), configuration fails on the others. We used the SO8 package (AS x4). We soldered 0805 10pF C0G capacitors between pins 2, 3, 5 and GND (pin 4). i.e. between D0, D1, D2 and GND. After this modification, the configuration works on all boards (tested at room temperature, at approx. -10°C and at approx +50°C). We do not like this solution, but we could not find a better one. It is not clear to us what causes the problem and why these capacitors solve the problem. An hypothesis is that the EPCQ-A might have faster edges than the EPCQ devices and that the capacitors increase the rise/fall times. This, in turn, would improve the quality of the signals at the other end (the FPGA side) of the tracks. Other ideas? A reply with more details is currently awaiting approval (due to the attached files). I expect it to be published over the following days.
