8 years agomigration from EPCQ to EPCQ-A
Hi, on a custom board we have successfully used an altera Cyclone V (5CEBA2) with an EPCQ32 (ASx4). Now we had to migrate from the EPCQ32 to the EPCQ32A. We used Quartus Prime Lite 17.1.0 a...
8 years agoHi,
I would assume you should generate the *.pof from the *.sof as stated under "Programming File Regeneration Guideline". That should do the required changes as you select the target Config-EPROM.(https://www.altera.com/documentation/tfb1498107381358.html#bkz1500385055860__table_jng_n3d_bdb) KR, Carlhermann
