dsun01's avatar
dsun01
5 years ago
Migrate from ArriaV GZ to Arria 10Sx
I got a project to convert Arria V Gz design to Arria 10SX, the FPGA is from TI's TSW14J56EVM, the trick part is the JESD204B core. we paid this IP. so we can compile based on Arria V Gz.
This is the first time I dealing with JESD204B and Arria V GZ.
If I directly change the Device family, the Quartus will remind me to update the IP. after I click automatic update. I got the following error message. I guess it may take me months or even longer to figure out by my self.
I hope the core we purchased was not bounded to Arria V GZ. if that is not the case, then I
hope expert who really know FPGA and Quartus give me some suggestion.
how to manually convert all functions that failed automatic update to the Arria 10
thank you very much,
David
Info: 2021.08.17.12:08:51 Info: p0: Generating jesd204b_altera_mem_if_ddr3_phy_core_181_d333jga_altdqdqs
Error: 2021.08.17.12:08:54 Error: p0: Error during execution of script generate_altdqdqs.tcl: jesd204b_altera_mem_if_ddr3_phy_core_181_d333jga_altdqdqs: Family Arria 10 is not supported
Error: 2021.08.17.12:08:54 Error: p0: Error during execution of script generate_altdqdqs.tcl: jesd204b_altera_mem_if_ddr3_phy_core_181_d333jga_altdqdqs: An error occurred
Error: 2021.08.17.12:08:54 Error: p0: Error during execution of script generate_altdqdqs.tcl: jesd204b_altera_mem_if_ddr3_phy_core_181_d333jga_altdqdqs: add_fileset_file: No such file C:/intelfpga/18.1/ip/altera/altdq_dqs2
Error: 2021.08.17.12:08:54 Error: p0: Execution of script generate_altdqdqs.tcl failed
Error: 2021.08.17.12:08:54 Error: p0: ERROR: Family Arria 10 is not supported
Error: 2021.08.17.12:08:54 Error: p0: 2021.08.17.12:08:51 Info:
Error: 2021.08.17.12:08:54 Error: p0: ********************************************************************************************************************
Error: 2021.08.17.12:08:54 Error: p0: Use qsys-generate for a simpler command-line interface for generating IP.
Error: 2021.08.17.12:08:54 Error: p0: Run ip-generate with switch --remove-qsys-generate-warning to prevent this notice from appearing in subsequent runs.
Error: 2021.08.17.12:08:54 Error: p0: 2021.08.17.12:08:54 Error: jesd204b_altera_mem_if_ddr3_phy_core_181_d333jga_altdqdqs: Family Arria 10 is not supported
Error: 2021.08.17.12:08:54 Error: p0: 2021.08.17.12:08:54 Error: jesd204b_altera_mem_if_ddr3_phy_core_181_d333jga_altdqdqs: An error occurred
Error: 2021.08.17.12:08:54 Error: p0: while executing
Error: 2021.08.17.12:08:54 Error: p0: "error "An error occurred""
Error: 2021.08.17.12:08:54 Error: p0: (procedure "_error" line
Error: 2021.08.17.12:08:54 Error: p0: invoked from within
Error: 2021.08.17.12:08:54 Error: p0: "_error "Family [get_parameter_value DEVICE_FAMILY] is not supported""
Error: 2021.08.17.12:08:54 Error: p0: ("if" then script line 2)
Error: 2021.08.17.12:08:54 Error: p0: "if {$device_is_legal == 0} {
Error: 2021.08.17.12:08:54 Error: p0: _error "Family [get_parameter_value DEVICE_FAMILY] is not supported"
Error: 2021.08.17.12:08:54 Error: p0: set_parameter_value MODULE_VALID false
Error: 2021.08.17.12:08:54 Error: p0: }"
Error: 2021.08.17.12:08:54 Error: p0: (procedure "my_validate" line 16)
Error: 2021.08.17.12:08:54 Error: p0: "my_validate"
Error: 2021.08.17.12:08:54 Error: p0: 2021.08.17.12:08:54 Info: jesd204b_altera_mem_if_ddr3_phy_core_181_d333jga_altdqdqs: "Transforming system: jesd204b_altera_mem_if_ddr3_phy_core_181_d333jga_altdqdqs"
Error: 2021.08.17.12:08:54 Error: p0: 2021.08.17.12:08:54 Info: jesd204b_altera_mem_if_ddr3_phy_core_181_d333jga_altdqdqs: Running transform generation_view_transform
Error: 2021.08.17.12:08:54 Error: p0: 2021.08.17.12:08:54 Info: jesd204b_altera_mem_if_ddr3_phy_core_181_d333jga_altdqdqs: Running transform generation_view_transform took 0.000s
Error: 2021.08.17.12:08:54 Error: p0: 2021.08.17.12:08:54 Info: jesd204b_altera_mem_if_ddr3_phy_core_181_d333jga_altdqdqs: Running transform merlin_avalon_transform
Error: 2021.08.17.12:08:54 Error: p0: 2021.08.17.12:08:54 Info: jesd204b_altera_mem_if_ddr3_phy_core_181_d333jga_altdqdqs: Running transform merlin_avalon_transform took 0.054s
Error: 2021.08.17.12:08:54 Error: p0: 2021.08.17.12:08:54 Info: jesd204b_altera_mem_if_ddr3_phy_core_181_d333jga_altdqdqs: "Naming system components in system: jesd204b_altera_mem_if_ddr3_phy_core_181_d333jga_altdqdqs"
Error: 2021.08.17.12:08:54 Error: p0: 2021.08.17.12:08:54 Info: jesd204b_altera_mem_if_ddr3_phy_core_181_d333jga_altdqdqs: "Processing generation queue"
Error: 2021.08.17.12:08:54 Error: p0: 2021.08.17.12:08:54 Info: jesd204b_altera_mem_if_ddr3_phy_core_181_d333jga_altdqdqs: "Generating: jesd204b_altera_mem_if_ddr3_phy_core_181_d333jga_altdqdqs"
Error: 2021.08.17.12:08:54 Error: p0: 2021.08.17.12:08:54 Info: jesd204b_altera_mem_if_ddr3_phy_core_181_d333jga_altdqdqs: real_altdq_dqs2: altdq_dqs2_arria10
Error: 2021.08.17.12:08:54 Error: p0: 2021.08.17.12:08:54 Error: jesd204b_altera_mem_if_ddr3_phy_core_181_d333jga_altdqdqs: add_fileset_file: No such file C:/intelfpga/18.1/ip/altera/altdq_dqs2
Error: 2021.08.17.12:08:54 Error: p0: "add_fileset_file $generated_file [::alt_mem_if::util::hwtcl_utils::get_file_type $filename 1 0] PATH $generated_file"
Error: 2021.08.17.12:08:54 Error: p0: ("if" else script line 2)
Error: 2021.08.17.12:08:54 Error: p0: "if { $is_vhdl } {
Error: 2021.08.17.12:08:54 Error: p0: add_fileset_file $generated_file [::alt_mem_if::util::hwtcl_utils::get_file_type $filename 1 0] PATH $generated_file $non_encryp_..."
Error: 2021.08.17.12:08:54 Error: p0: "if {[string compare -nocase $::param_array(USE_REAL_RTL) "true"] == 0} {
Error: 2021.08.17.12:08:54 Error: p0: if {[string compare -nocase $device_family "ARRIAV"] == 0 || [string compar..."
Error: 2021.08.17.12:08:54 Error: p0: (procedure "run_generate" line 188)
Error: 2021.08.17.12:08:54 Error: p0: "run_generate $outputname $outdir $param_str $fileset_type"
Error: 2021.08.17.12:08:54 Error: p0: ("if" else script line 228)
Error: 2021.08.17.12:08:54 Error: p0: "if {[string compare -nocase [get_parameter_value MODULE_VALID] false] == 0} {
Error: 2021.08.17.12:08:54 Error: p0: _error "Current parameterization is not valid. Cannot generate HDL"
Error: 2021.08.17.12:08:54 Error: p0: ..."
Error: 2021.08.17.12:08:54 Error: p0: (procedure "generate_fileset" line 2)
Error: 2021.08.17.12:08:54 Error: p0: "generate_fileset $outputname QUARTUS_SYNTH"
Error: 2021.08.17.12:08:54 Error: p0: (procedure "my_quartus_synth" line 3)
Error: 2021.08.17.12:08:54 Error: p0: "my_quartus_synth jesd204b_altera_mem_if_ddr3_phy_core_181_d333jga_altdqdqs"
Error: 2021.08.17.12:08:54 Error: p0: 2021.08.17.12:08:54 Info: jesd204b_altera_mem_if_ddr3_phy_core_181_d333jga_altdqdqs: Done "jesd204b_altera_mem_if_ddr3_phy_core_181_d333jga_altdqdqs" with 1 modules, 0 files
  • Yes, it answered my question. thank you very much.
  • Nurina's avatar
    Nurina
    Hi, did the above comment help?
  • sstrell's avatar
    sstrell
    I don't know anything about that core specifically, but if an automatic core regeneration fails when you move to a new device, you'll need to recreate and regenerate the core from scratch from the IP catalog. If you know the correct parameter values, it's not too difficult.
    This is not a licensing issue.
    • dsun01's avatar
      dsun01
      thank you very much, this answered my question.
