11 years agoMicron Nand Flash program operation not possible when ECC is enabled.
Hello.. I am using Micron nand flash 16GB device. I have successfully programmed it and am able to read the values from nand flash. But after programming when I check the status whether it is success...
11 years agoWhat chip are you using? I'm not aware of any micron flash chips that are 12 bits wide (only 8 or 16). If your chip has an extra area for ECC associated with each block, the Altera system doesn't know about it. See your flash chip's data sheet on how to program that.
