11 years agoMicron Nand Flash program operation not possible when ECC is enabled.
Hello.. I am using Micron nand flash 16GB device. I have successfully programmed it and am able to read the values from nand flash. But after programming when I check the status whether it is success...
11 years ago8 bits is not wide enough to use ECC. The ECC circuit stores additional data along with the 8 bits. I don't remember how many you need for 8 bit ECC, but it is at least 10 bits. Boards that use ECC have wider data widths to accommodate the ECC bits (e.g. 32 data bits + 4 ECC bits => 36 bit wide memory).You can't make ECC work for flash on this board because you don't have the extra data width.
