11 years agoMicron Nand Flash program operation not possible when ECC is enabled.
Hello.. I am using Micron nand flash 16GB device. I have successfully programmed it and am able to read the values from nand flash. But after programming when I check the status whether it is success...
11 years agoWhat bit width? Do you have the extra bits needed for ECC? If so, are they programmed with the correct values?
