jaylong
3 years agoMetastable
I'm a beginner, and after designing an adder, I wanted to use SignalTap to check the synthesized signals. However, I found that the signals are not as expected. It seems to be due to metastability is...
RichardT_altera
3 years agoThere is no SDC file in your design, so this is likely an issue with your design.
You can refer to this document on how to use SDC constraints:
You may also want to check out YouTube for resources related to timing analysis.
Link: https://www.youtube.com/watch?v=O6kf1_fSaIA
Richard Tan
p/s: If you find any answers from the community or Intel Support to be helpful, we encourage you to mark them as the best answer or rate them 4/5 in the survey.
- jaylong3 years ago
I'm using Timing Analyzer, and when I click on 'constraints' and then 'create clock' to set up my clock signals, after I finish and compile, my clock signals disappear. What could be the issue?
