jaylong
3 years agoMetastable
I'm a beginner, and after designing an adder, I wanted to use SignalTap to check the synthesized signals. However, I found that the signals are not as expected. It seems to be due to metastability is...
FvM
3 years agoHi,
does your design meet timing? If not (very likely it doesn't), why do you complain about unexpected results?
I'm not sure what you want to achieve, as a general rule:
- don't use clock as data
- don't use divided or phase shifted clocks, except for special purposes e.g. driving peripherals
