8 years agoMemory WRITING issue
Dear, I have a procedure (Sort) that read two numbers in each cycle. and return the max and the min. I am reading two numbers from mif file , the problem is that I want to write back the result re...
8 years agoThe weird thing is that I am using dual port , in reading these two locations, it . I am using now different memory for each operations , but the number of logic element is so large . Thank you for your reply brother.
