8 years agoMemory WRITING issue
Dear, I have a procedure (Sort) that read two numbers in each cycle. and return the max and the min. I am reading two numbers from mif file , the problem is that I want to write back the result re...
8 years ago --- Quote Start --- Dual ports means each port can do either write OR read on each port in clock cycle, not both. --- Quote End --- I added another process, ShowResults:Process(Clock,show) variable i:integer range 0 to 7:=0; begin IF rising_edge(clock) and show='1' THEN D<=ram1(2*i); S<=ram1(2*i+1); i:=i+1; end if; end process; acmain<='0' when Z=16 else '1'; --Z is a counter to read 16 elements and then stop activating the first process.acmain is in sensitivity list of first process I listed in first post. show<='1' when acmain='0' else '0'; So, I activate it when I deactivate the first process , So I can either read or write. However Still unable to infer to memory. What is the best solution for that
