11 years agoMemory works in simulation, but not on HW?
Hello guys, I used the megafunction wizard to create 1-Port RAM. Then I managed to make the input and output bus as a single bi-directional bus. So the top level entity is : entity SRAM is port ...
11 years agoJust a couple of questions/statements that might help:
Have you simulated what happens if both OE and WR are low and high? Also, sometimes, IO is active-low which means you have to invert the signal. Are you sure the microcontroller code is correct? Can you check with a scope or LEDs? [edit]Oh, and are you sure about your connections? All wires connected to the correct pins?[/edit]
