11 years agoMemory works in simulation, but not on HW?
Hello guys, I used the megafunction wizard to create 1-Port RAM. Then I managed to make the input and output bus as a single bi-directional bus. So the top level entity is : entity SRAM is port ...
11 years agoIf I understand correctly you use an external (no NIOS etc.) microcontroller. Do you synchronise the clocks and data or how do you interface this?
