17 years agoMemory Test fails whith 256-MB DDR2
When using the SDRAM DDR2 with 64-bit data bus width, the memtest fails! And the failure occurs only in specific locations (spans of 0x10): --- Quote Start --- ERROR: DDR2 was not filled...
17 years agoAlso search for "Board Bring-up" in this document if you are not familiar with the tests I'm referring to: http://www.altera.com/literature/hb/nios2/edh_ed51010.pdf
