17 years agoMemory Test fails whith 256-MB DDR2
When using the SDRAM DDR2 with 64-bit data bus width, the memtest fails! And the failure occurs only in specific locations (spans of 0x10): --- Quote Start --- ERROR: DDR2 was not filled...
17 years agoAre you using Nios II and the memtest software or your own custom method? Also what is the data width and burst lengths set to for both the SDRAM controller and the master performing the read/write accesses?
