16 years ago
Megawizard command line Help
I would like to configure a 1-port ram with turning on clock enable. I tried to run "qmegawiz -silent module=altsyncram -f:param.txt single_port.v" in command prompt but I am unable to generate megawizard file. I get many errors in command prompt. Pls find my attach screenshot more details about errors.
Contents of param.txt:
clock_enable_input_a=BYPASS
clock_enable_output_a=BYPASS
intended_device_family="Stratix IV"
lpm_hint="ENABLE_RUNTIME_MOD=NO"
lpm_type=altsyncram
operation_mode=SINGLE_PORT
outdata_aclr_a=NONE
outdata_reg_a=unregistered
power_up_uninitialized=FALSE
numwords_a=32
widthad_a=5
width_a=5
width_byteena_a=1
clocken0=used
I can generate megawizard file by running "qmegawiz -silent wizard="RAM: 1-PORT" intended_device_family="stratix IV" single_port.v" in command prompt but I could not enable clock enable.
Does anyone know how to generate megawizard file for single port ram with turning clock enable using command-line? I would appreciate if you could response me as quick as possible.
