9 years agoMega Wizard dual Clock FIFO Strange behavior !!!!!
Hullo guys , I have a Cyclone ||| board and im working on an application that uses dual clock 16-bit , 16-word deep FIFO . The write signal and clock r from the FPGA itself, and the read signal and ...
9 years agoThe DCFIFO is a very old and very well tested IP, so I can only assume there is a problem with your design. the data path has no link to the control path at all, so your problems are impossible. The only issue can be a design issue.
Can you post the code ? or the project?
